Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - What's this metal in my oil pan?
  #20 (permalink)
Old 08-07-2010, 02:28 AM
ericnova72's Avatar
ericnova72 ericnova72 is online now
More for Less Racer
One thing I forgot... The 400 SBC block requires a necked down oil pump drive due to the larger main bearing bores in the block. If a pump drive shaft that is not reduced diameter is used, it will rub hard on the hole in the block and main cap that it passes through, and could well be related to your problem.
