What's this metal in my oil pan? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-06-2010, 06:17 PM
sqzbox's Avatar
My pipes are my music
Advise? There's nothing more manly than raising raising your kids!
  #17 (permalink)
Old 08-06-2010, 09:15 PM
406cu.in. of tire smokin' fun
Last journal entry: 406 Build Thread
Ok, I pulled the distributor. Those pieces are definitely from the wear plate. There appears to be a shim between the wear plate and the gear, so I am even more lost.
There is some wear from the thing spinning, which appears to have forced the whole shaft upwards, which in turn started to melt the cap and rotor. I always thought that the camshaft would pull the shaft down, but that doesn't seem to be the case.
My previously complemented wear pattern on my distributor gear doesn't look so good either.
I have no idea what went wrong here.
  #18 (permalink)
Old 08-06-2010, 11:36 PM
ericnova72's Avatar
More for Less Racer
Looks like either the intake manifold is machined too low where the distributor sits(or excessive block/head milling), or the distributor housing collar is machined too high(Chinese?) and the distributor shaft is jammed hard against the oil pump drive rod bottoming everything out. I'd want to inspect the pump now too, for scoring of the end plate and end of gears.
Oil pump drive rod could be too long also, there are three lengths that all look the same to the eye but with 1/8" or so difference - standard SBC, SBC w/BBC pump(slightly shorter), and BBC(longer), but I would be looking at distributor height first for manifold ot housing problems.
Moroso sells a distributor to manifold shim kit for this reason, did you check at assembly that the pump, drive rod, and distributor all had adequate end play??
Gear appears to show distributor sitting too deep in the block also.
  #19 (permalink)
Old 08-07-2010, 01:02 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You got off light- the damage will be limited to a distributor thrust washer, cap and rotor, probably an oil pump and a shim kit to set the distributor height/gear mesh.
The labor is another thing.
You might want to go ahead and get shims to set the distributor end play. Shims linked are for a 1/2" shaft diameter, check yours to see what it is before ordering.
The relationship of the dist. gear to the cam gear causes the dist. shaft to rise upwards- so when checking the pattern, be sure the shaft is fully up w/all clearance removed from the gear end- that is how the dist. shaft and gear is when the engine is running.
I do not believe you could have broken the tangs off an OEM thrust washer like that- the OEM piece is thick enough that I believe it would have taken out the aluminum housing first. But in any event, that dist. shaft had to have been really bound up to do what it did.
  #20 (permalink)
Old 08-07-2010, 02:28 AM
ericnova72's Avatar
More for Less Racer
One thing I forgot... The 400 SBC block requires a necked down oil pump drive due to the larger main bearing bores in the block. If a pump drive shaft that is not reduced diameter is used, it will rub hard on the hole in the block and main cap that it passes through, and could well be related to your problem.
  #21 (permalink)
Old 08-07-2010, 03:35 AM
Originally Posted by Pre-Tuner
I actually had the distributor recurved about 150 miles ago, and the place that did it commented on how nice the wear pattern looked.
If the distributor looked fine after 250 miles, and you put on another 150 since recurving (400 miles), makes me wonder what exactly was done when you had it recurved. If you didn't do anything else but pull the distributor, and put it back in...assuming with the same gasket between the dist. housing and intake...I would make a call to the guys who did your recurving. Does it look like they may have added a shim to take-up excessive play between the gear and housing?
I can honestly say I've never seen this happen. All the distributors, all these years...some were sloppy as hell...up-and-down and/or side-to-side...some were tight...and I've never seen this. But then...I've never had my distributor recurved. Hmmm. 0.o
  #22 (permalink)
Old 08-07-2010, 09:36 AM
I did put about 250 miles on when I first got it, and then decided it needed to be recurved because I needed more initial timing. Nothing was wrong with it when I took it out, but now there is. I'm not sure what they did to it, but I imagine they wouldn't admit to it. I will definitely be talking to them. I don't know if there is an extra shim or not because I don't know what it is supposed to look like.
The intake is untouched and the block was only decked enough to make a nice sealing surface for the heads, which ended up being .008".
I have the 400 oil pump rod which is necked down. The pump is a standard volume pump, so nothing special.
It's a Mallory HEI distributor, so I would think the machining would be accurate coming from a name brand company. Especially since it started off fine.
The gear teeth didn't look like that when I pulled it at 250 miles. The wear pattern was in the center just like it should be.
  #23 (permalink)
Old 08-07-2010, 01:58 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
On OEM HEI's, there is the thrust washer w/tangs against the distributor. Then a shim. Then the gear. If the end play was set, usually there will be several shims or possibly a thick shim to replace the ~0.015" shim that the dist. comes with.
As long as the dist. isn't bottomed out, there's a fairly wide leeway for where the mesh occurs on the gear itself, w/no adverse results. The pattern has to be all on the gear, not running off the top or bottom.
  #24 (permalink)
Old 08-08-2010, 08:51 PM
Well, my Dad got back in town from vacation and he thinks the distributor is still usable after the bottom is cleaned up (he's a mechanic). He has some thrust washers that will work, and some shims if needed. He isn't sure what happened either, but agreed that I should take it to the place that recurved it to see what they have to say, which I will try to do tomorrow. When I reinstall it, if the oil pump shaft isn't floating, then I can grind it a little for clearance since I already have the pan off.
  #25 (permalink)
Old 08-09-2010, 12:53 PM
DoubleVision's Avatar
I was going to say the same thing Eric did about the difference in the 400 SBC shaft, but the last time I did so many years back nobody believed me.
  #26 (permalink)
Old 08-09-2010, 03:18 PM
The thing is, if there was a problem with the internal parts, it would have been damaged within the first 250 miles...but it wasn't. The damage occured after recurving...in the 150 miles after installation. Which means either:
1. Pre-Tuner did something "different" when reinstalling the distributor, OR
2. The people who did the recurving did something to change the position of the dist. gear.
I vote for #2. If the metal tangs weren't sheared off when the dist. was first removed, it's safe to assume all the internal engine parts are correct.
  #27 (permalink)
Old 08-09-2010, 05:20 PM
Ok, I just got back from the place that recurved it. The guy that did the work said that he has never seen this type of damage this bad before. The shim and the thrust washer were all but welded to the gear. He had to use a hammer and chisel to get them apart after removing the gear. He couldn't say for sure what happened, but he thinks it's a combination of me tightening the distributor down a tiny bit more due to reusing the gasket and the fact that he DID use a shim to take up some clearance in the shaft. He said that the shim alone would not cause damage this bad unless the shaft wouldn't rotate after he was done. I know it rotated when I picked it up.
He also thinks the distributor is reusable, so I am going to have him repair it. He is going to put a new gear on with a new thrust washer and shims to take up the clearance. Then, after I get it back, he said to use the paint that you use to set up a rear end and paint the gear. Then install the distributor and turn the motor over by hand to see where the pattern is. If it needs to be adjusted, I'll have some shims to do it with. I'll also check to make sure that the oil pump drive shaft is not binding.
  #28 (permalink)
Old 08-09-2010, 08:25 PM
Smarter than i look
Last wiki edit: Upgrading to HEI
Wiki Edits: 2
.008 may not seem like much, but if the dist was borderline before, the extra shim he put in may have sent it over the edge.
Also, you remember if there was more than one gasket on the dist when you pulled it the first time? Broke people (like me) dont buy shim kits, they stack dist gaskets to space the dist up.
And because ive been down the same road before, was the motor a little hard to crank? because if it was, you can be sure the oil pump is damaged.
  #29 (permalink)
Old 08-09-2010, 09:38 PM
It cranked up fine. I took the pump apart and it looked good to me. There was some VERY light wear, but nothing you could feel with your finger nail. The machine marks in the metal are still visible.
I don't know how close it was before because the wear on the teeth were exactly where you'd want it to be. I bought this distributor new when I rebuilt the engine. After this whole thing, I started looking at everything a little closer. I found that there was two gaskets stuck together, but that would have made the distributor ride a little high. The gaskets were stuck together from Mallory, because what they sent me with the distributor I used.
I can tell you that after this setback, I will be checking/rechecking the teeth wear and I will be buying shims if needed.
Honestly, this is my first ground up engine build. I've bought crate engines before and done a fair amount of engine work, but most of it is just stock replacement pieces. I have learned a lot doing this, but I think the two things I have learned most is that you can never check too much and nothing aftermarket fits like it should.
  #30 (permalink)
Old 08-14-2010, 09:36 PM
I got the distributor back and it is installed. He cleaned up the aluminum at the bottom, lubed everything, one extra shim, new gear, cap, and rotor.
Since I had the pan off, I was able to check the pump drive shaft for binding. Guess what, that was the whole problem. I never thought that taking .008" off of the heads would be enough to cause binding, but either that was the whole reason, or it was a combination of things. Live and learn I guess.
Instead of getting shims for the distributor at the intake, I just ground a tiny bit off of the pump drive shaft. It should be good enough now.
I have one question though. Since I had to remove the pump, do I need to reprime the engine before I start it?
Oil Pan leaks my oldcar Hotrodding Basics 4 11-15-2009 07:43 AM
Welch Plug - In or Out? Gun Laker Engine 5 11-03-2009 07:50 AM
400 Small Block oil problems bac6772 Engine 40 07-05-2007 12:49 PM
Jiffy lube rant: what would you do? killerformula Hotrodders' Lounge 35 02-16-2006 06:07 PM
Front oil pan seal on Small Block Chevys gearhead77 Engine 19 09-26-2004 08:58 PM
