10-15 PSI is really the most you would ever need on a 6/71 blower... remember, that it was designed and sized to feed a 426 CID 6cyl diesel equally in volume ( diesels don't use superchargers to boost )... so that's a lot of air volume.
buy a turbo then... the principals of forced induction are the same, except the turbo relies more on preassure and less on volume...
not sure why you would want to crank more preassure than you need to just because the engine is " built for 25 PSI ". which is what, a forged rotationg assembly/ O ringed block with copper gaskets?.. you will need at least that if you try to put a lot of boost thru a 6/71 |
well, the efficiency range for a 6/71 is 8-12 PSI.
With the old stock 350 at a 12% overdrive i got 14lbs of boost. I can overdrive this blower up to like 70% from what the techs said, but that doesnt sound right to me. |
That's about right, HOWEVER your heat will rise DRAMATICALLY, The heat will kill your engine and your blower, not the speed. The pressure/flow is outside its efficiency zone. Its not about the blower speed at all, if you overdrove it 70% on a 502 BBC it could survive (though it'd still produce a hell of a lot of heat, on a sbc the amount of heat generated from the boost is tremendous though. If you want that much boost you need to have some serious intercooling capabilities.
I could not imagine pushing 25lbs out of a 671. I would definately be concerned about the heat build up. This old style huffer is not inter-cooled, I would think things would start melting at that range. Pushing 25lbs will not be too efficient for this blower, (heat soak). To answer your question, it would not be wise, even on a forged bottom end....
A large part of my job is specing pumps- for both gasses and liquids, and I can tell you boost is a HUGE part of it, ignore it and expect a failure, no matter what RPM the blower may be turning. You can't run a stock 6-71 up to 25psi. |
| 3 speed maual with auto overdrive | Ray Bell | Transmission - Rearend | 1 | 09-13-2010 12:59 AM |
| 700R4 or TH400 w/ overdrive | 53LEDSLED | Transmission - Rearend | 8 | 05-28-2007 08:22 AM |
| saginaw 4 spd overdrive | scatsihc | Transmission - Rearend | 0 | 02-05-2006 07:44 PM |
| 4L60E trouble with overdrive | Please Help | Transmission - Rearend | 2 | 03-19-2004 07:20 AM |
| Overdrive transmission | merkery | Transmission - Rearend | 1 | 06-25-2002 09:25 PM |
