Whats This In My Carb - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-13-2007, 11:40 AM
Canadian Charlie's Avatar
The Big Money
Last journal entry: New Air Line Part 2
Here is my problem:
I have a Chevy Silverado with a small block in it and lately the idle has been going from 1000RPMs to 3000RPMs at idle, really jumping around. So a couple a days ago I pull the carb (Holley 750 double pumper) thinking I have a vacuum leak or something. Today i go and remove the fuel bowls to find a brownish sludge in the secondary bowl, the primary bowl is super clean.
What is causing this?
Also on the intake manifold right under the seconday bowl there is a puddle of gasoline. I have to admit that the mounting point on the rear of the intake is stripped so my carb is only held on by 3 bolts
The jets are not clogged
Name:	May 2007 030.jpg
ID:	21177   Click image for larger version
Name:	May 2007 036.jpg
Old 05-13-2007, 12:00 PM
Jmark's Avatar
Did the carb sit dry for a while? Looks like it dried out and left behind some moisture deposits.
Old 05-13-2007, 01:39 PM
The Big Money
From what I know there was always fuel in it
Old 05-13-2007, 01:48 PM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
Looks like when gas stays in a carb for to long and turns to varnish crap. Maybe your secondaries are not opening and fuel is just sitting in that bowl and going bad...
Holley 4777 carb. questions. TVR383 Engine 16 07-05-2009 02:23 PM
Demon or Holley Carb for 306 Ford? Dino Boreanaz Engine 10 12-09-2006 06:04 PM
700 R4 tv cable hook up at carb murrsue Transmission - Rearend 4 10-18-2006 09:50 AM
Holley Carb. Question crusherdbuzz Engine 2 07-02-2006 03:25 PM
Holley carb has me at wit's end cool rockin daddy Engine 23 06-02-2005 02:38 PM
