Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Whats This In My Carb
Old 05-13-2007, 11:40 AM
Canadian Charlie's Avatar
Canadian Charlie Canadian Charlie is offline
The Big Money
Last journal entry: New Air Line Part 2
Here is my problem:
I have a Chevy Silverado with a small block in it and lately the idle has been going from 1000RPMs to 3000RPMs at idle, really jumping around. So a couple a days ago I pull the carb (Holley 750 double pumper) thinking I have a vacuum leak or something. Today i go and remove the fuel bowls to find a brownish sludge in the secondary bowl, the primary bowl is super clean.
What is causing this?
Also on the intake manifold right under the seconday bowl there is a puddle of gasoline. I have to admit that the mounting point on the rear of the intake is stripped so my carb is only held on by 3 bolts
The jets are not clogged
Name:	May 2007 030.jpg
ID:	21177   Click image for larger version
Name:	May 2007 036.jpg
