Whats oil is a good oil for Solid Roller Engine? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-23-2009, 04:43 PM
Hello everybody,
I just finished my 434 SBC and was wondering what would be a good oil for a soild roller street engine. I had problems with my compcam lifter before so i went to Isky Redzone just don't want to make a bad mistake on useing cheap oil.
Old 09-23-2009, 05:08 PM
diamond mike's Avatar
throw me under the bus agian
oil
fully synthetic, always, all except motors that are near a rebuild ( and new motors not broke in yet, extreme slippyness wont allow rings to seat correctly)
Old 09-24-2009, 04:32 AM
Amsoil with zinc.
Old 09-24-2009, 05:01 AM
Guy Hiltz's Avatar
I use Valvoline non synthetic 10W30 motor oil,although I do pour a bottle of EOS in every other oil change.This is in my solid roller big block.I probably change the oil more than is really needed,but this gives me a chance to grease all the fittings,and visually inspect the underneath.So,IMO,changing the oil as often as I do negates the need to use synthetic oil.
Guy
Old 09-24-2009, 05:16 AM
I run castrol 20/50 in my race engine no issues
Old 09-24-2009, 06:49 PM
camaroman7d's Avatar
Call your cam manufacturer and see what they suggest. You might be surprised.
Old 09-25-2009, 08:49 AM
How fast is fast enough?
I run Valvoline Synthetic in everything, except on break in as prviously noted. Then I run Valvoline 10W-30 or straight 30W with Comp Products ZDDP additive.
Old 09-25-2009, 11:37 AM
runn141's Avatar
SB S10
Old 09-29-2009, 09:54 PM
oil
how long for break in with moly rings till sythetic can be used ??
Pinging on 03 Chevy 5.3 Engine in Suburban bry21317 Engine 42 10-02-2011 07:35 PM
Oil Weight (yes, again) skizot722 Engine 40 06-26-2008 11:11 AM
Oil leak rear of engine - why? and reuse intake gaskets? sabino56 Engine 12 12-02-2007 01:33 PM
Synthetic Motor Oil In 454 Rebuild leejoy Engine 36 11-20-2006 02:34 PM
Jiffy lube rant: what would you do? killerformula Hotrodders' Lounge 35 02-16-2006 06:07 PM
