whats this part called? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-08-2008, 12:05 AM
shadowismydogsname's Avatar
hi, iam wondering what this part of the vehicle is called(the area in the red rectangle)and if there is normally any beams in this.
ID:	32332   Click image for larger version
ID:	32333   Click image for larger version
ID:	32334   Click image for larger version
Old 09-08-2008, 12:22 AM
Huckmag's Avatar
Last journal entry: Change of Plans
Rocker panel.
Old 09-08-2008, 02:46 AM
thank-you huckmag
Old 09-08-2008, 06:48 AM
Last journal entry: More painting pics
In your part of the world it might be called the 'sill' as in door sill.
I seem to remember this word being used in the UK and europe although it's been a while since I was there.
Old 09-08-2008, 08:43 AM
CustomConspiracy's Avatar
Both right?
This may be stupid but I think you are both right.
The surface that is curved down on the outside is the rocker panel, and the flat part n the top side is the door sill.
I could be wrong.
Old 09-08-2008, 12:12 PM
Huckmag's Avatar
"thank-you huckmag"
My pleasure As for the beams (frame rails), I would say for a unibody car like yours there were none there. If you wanted to shore it up by adding some, even temporarily, it would be fine. Looks like you are doing a thorough job of rust removal. Best of luck with your car!
BTW I think Customconspiracy is correct. I say this because the aluminum trim on top of the area is called a sill plate.
Duh, what is this steering part? [NFBS]Flash Suspension - Brakes - Steering 17 07-24-2005 02:59 PM
got part # need to know whats the use. Parisienne66 Transmission - Rearend 1 07-13-2005 08:48 PM
Lost my part time job! Maverick Hotrodders' Lounge 9 04-17-2005 01:43 PM
Question about removing roof 86caprirs Body - Exterior 3 03-27-2005 12:21 PM
Where is GM part # for '59 corvette body? CHEV66JB Body - Exterior 0 05-14-2003 05:24 PM
