whats this part called? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-02-2012, 10:37 AM
75chev4x4's Avatar
Hey guys ive had my edelbrock 1406 off my 350 for a few days now waiting on a gasket for it. Got to playing around with an old quadrajet I had in a parts box #10708213 and cleaned it up to see if it would run. After figuring out all the routing of the vac lines I realized it had a hot air choke. I had a spare one of those metal tubes that go into the exhaust port on the intake but its in rough shape and I would like to get a new one but cant find one anywhere. What are the called exactly. Btw that quadrajet runs really nice after adjusting it and driving with it the power is very nice compared to the edelbrock and the choke is more reliable then the electric I had on ky 1406. I think ike gonna keep the quad on now. I know its old technology but its cool to me and I like the way it works/runs.
Old 03-02-2012, 01:42 PM
engineczar's Avatar
If you use google images and type in quadrajet choke tube there are several examples of what I think you're referring to part way down the page.
BSE Racing Engines
Old 03-02-2012, 01:48 PM
techinspector1's Avatar
Wiki Edits: 326
Cliff Ruggles should have all those Qjet pieces....
http://www.cliffshighperformance.com/
Old 03-02-2012, 01:58 PM
75chev4x4's Avatar
Couldn't find it on there. Summit should sell it I just cant find them.
Old 03-02-2012, 02:06 PM
Wiki Edits: 326
Make a phone call to Cliff....
Old 03-02-2012, 02:08 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
You can't find Summit Racing? Here
Oh, you mean can't find the parts.....
Semper Fi
Old 03-02-2012, 02:11 PM
engineczar's Avatar
on the Summit site search for choke tube in the keyword search box
Looks like there's 2 manufacturers who make reproduction tubes. Classic tube and Right Stuff detailing
BSE Racing Engines
Old 03-02-2012, 04:07 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You can make a tube.
There were two types choke tube to choke housing connections used (see photo for details). One was a push-on fit at the choke housing w/a synthetic rubber collar that goes over the choke housing nipple and has the tube fit into it on the other end. These are the easiest to work with. Then there is a threaded choke housing nipple. It, too, can be fitted w/a rubber collar-type affair.
The tube itself can be made from copper, aluminum or steel tubing.
The tubes were covered w/an insulating sleeve to help hold in the heat. Use a spark plug wire sleeve for this.
Old 03-02-2012, 05:01 PM
Last journal entry: My Last Hot Rod
Hmm
older is usually better, and better made, and probably made in the good ole USA
Whats the part called that holds in the rear main seal? atomicrockerdude Engine 4 01-11-2010 10:41 PM
700R4 Whats the part directly behind the pump called. Chevy350Sb Transmission - Rearend 2 10-21-2009 11:15 PM
brake part, whats it called old fords Suspension - Brakes - Steering 7 02-08-2009 12:14 AM
whats this part called? shadowismydogsname Body - Exterior 5 09-08-2008 12:12 PM
What is the part called? D200Dodge Engine 40 01-30-2005 01:27 PM
