whats is it really - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-14-2012, 07:02 PM
whats is it really
have 73 350 chevy motorwould like know little more has bouble hump heads cast numbers are 463777 numbers on front are T1004DTW any info be great
Old 07-14-2012, 07:14 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Poke around in Chevy VIN, Trim Tag and Drivetrain Information & Decoding
Semper Fi
Old 07-14-2012, 09:17 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Not finding DTW anywhere. Check and make sure of those letters.
Old 07-14-2012, 10:38 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Info for ID'ing casting numbers, suffix, etc., here.
The casting number and suffix don't show up. Often suffix codes from truck engines aren't in the data bases. The casting number should be, however. If you have misread it and it is really 46077, it's a 1976-'79 305.
Old 07-16-2012, 02:39 PM
no that is the right numbers the date stamped on it is a 73
Old 07-16-2012, 02:59 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The c/n above should read 460777, and it's a block c/n. Are you saying the head c/n is 463777? Not that it matters, those numbers do not show up, period.
Old 07-16-2012, 03:20 PM
it is the block cn and i navnt found it also was just hoping sombody else had better info than i could find thanx
Old 07-16-2012, 03:30 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
b a good idea to run the crank # and measure the bore to be positive you have a 350
chevy, engine identification
whats up dragracer2027 Introduce Yourself 3 12-12-2009 07:23 PM
Overhaul kits, whats good whats not?? oldsmobilekindofguy Engine 3 09-05-2007 06:48 AM
whats up??????????? michaelbean2002 Introduce Yourself 1 06-13-2007 10:15 PM
whats up fatboy58 Introduce Yourself 1 05-09-2007 06:58 PM
Whats hot. whats not.. 2wld4u Engine 29 11-17-2003 11:33 PM
