whats the safe running temperature for air a compressor? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-11-2006, 11:50 AM
montea's Avatar
tryn to learn
Whats the safe running temperature for a air compressor? i have a 20 gallon 5hp(peak) Campbell housefeld unit and the cylinder head was at max 258 degrees Fahrenheit today and the motor was around 120.
Or do you guys even bother checking?
Old 09-11-2006, 05:24 PM
After running the compressor for 12 min straight my valve area was about 260*F, the cylinder area was 150*F pump body area was 85*and tank temp was right at 100*F. This is with the breakin oil which is mobile Rarus 427, after breakin will go to Amsoil ISO 100 PCK which hopefully will run a little cooler. Motor temp was around 80*, 1" hose was 85* and first 5' of 1" pipe was almost 80* after which temp fell basically back to room temp of 71*. How long were you running it to get that temp?
Steve
Old 09-21-2006, 12:31 PM
TechnTool's Avatar
OldSchool MotorHead
If I am going to do a big job, and the compressor is going to get a workout, I put a small squirell cage fan blowing directly on the cooling fins of the cylinder. I started doing this after I noticed smoke comming off the cylinder during a major job. So, a what temperature does the grit and grease on a compressor smoke? I dunno, but for me it was too hot. I'd say if you have temp concerns, buy a small fan for it like I did, it works great. I do the same for my welder also.
Old 09-21-2006, 03:46 PM
Irelands child's Avatar
There isn't much of a fan on these things - mine is the vanes on the compressor pulley. And without a supplementary fan runs quite hot - though not as high as reported in this thread.
The compressor should be in a place where there is some sort of air positive circulation and if you want it to live, almost any kind of a fan will help.
My compressor is a 6.5 Peak Hp 30 gallon Lowes/IR unit. They specifically say to not use any detergent oil because it will carbonize. My opinion of this is bull-pucky. LESS CARBON - that is one of the reasons for synthetics. They recommend 30 weight. I'm using 10-40 Castrol Syntec 50% synthetics/50% natural oil. The compressor is now running cooler which means less water vapor in the air lines, and hopefully means a longer life for the compressor, my water traps and my tools. I'll probably change to pure synthetic next time if the compressor survives this experiment. We'll see
Dave
Irelands child
Old 09-21-2006, 05:16 PM
I agree about the fan, I have a 36" that I would put on it if it was going to be run heavy. About compressor oil, the mobile rarus 427 I have in it for breakin has a pourpoint of 45* F and the amsoil it will be replaced with has a pourpoint of -45* F. From what I've been told it isn't good for the compressor to run much closer than 20* to the pourpoint of the oil, if it is -25* F I have no intention of being out in the barn. Flash point of this oil is 507* F so it should give good protection unless it is really being abused. Really like synthetic, run it in everything I have.
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 10:36 AM
air lines CARGUY Garage - Tools 96 11-16-2006 05:11 PM
327 SBC running temperature? 1 Day Engine 3 09-03-2006 09:59 AM
Whats the correct temperature my 350 should be running at? batman09 Engine 101 10-23-2005 01:29 PM
Oil Temperature and oil types (long) TurboS10 Engine 36 03-01-2005 02:51 PM
