not trying to discourage you but when the guide coat in the low finally disappears it's still there. You'll usually have to re-guide coat it a few times to get it out to where you can't notice any distortions in reflections. If you re-guide coat it you'll probably notice it re-appear but not so defined. The more you guidecoat it the less it stands out til you finally guide coat it and all the guidecoat sands out evenly at the SAME TIME. THAT is when you know it's gone. Just trying to give you a heads up cause if you have all primer on it with no filler or metal poking out it's something I'd consider doing if I were you.
