Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - What's the secret/trick to skim coating panels
  #125 (permalink)
Old 07-03-2012, 10:34 PM
Lizer Lizer is offline
I never only guide coat it once. Usually three times unless I can't go down anymore, in which case I shoot more primer or if necessary, spot fill with putty. Generally by the third time it will all sand away at the same rate.
