That is called the "center block", it locates the spider gear pinion shafts and also contains the preload springs for the clutch pack....it's supposed to be there.
You can't see the bolck in your picture, but ericnova got it right. Your Traction Lock differential has one long cross shaft and two short ones. The block holds them all in place, and as ericnova said, the preload springs for the clutches are also in this block.
Thank you again i do appreciate you guys help Iask the same question to much. Thats not a good thing with me. It can indicate health woes. I DO thank you all very much, Specially those who would otherwise -get sore at me about it. I'll get this kar done with help from this forum, i know that. cheers bob s my wife calls it selective hearing she oughta know she gets a lot of it from me:spank:... bob s.
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
