Whats stronger,, round tubing or square ??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-15-2005, 06:09 PM
I am doing some reinforcing on my frame and I was planning on using 1" or 1/12" round tubing but I was wondering if square tubing would be stronger?
Old 02-15-2005, 06:59 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Pound for pound, round tubing is the strongest cross-section available. People use rectangular 'cause it is so much more convenient to hang stuff on. Ever notice a total lack of square tubing in stressed areas on a race car chassis?
Old 02-15-2005, 08:11 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
round
Round chromemoly is right near the top.
Old 02-18-2005, 07:18 AM
BillyShope's Avatar
Philippines Cowboy
Last journal entry: THE TRACTION DYNO
You have to be careful, with this sort of question, that you're comparing apples with apples, so I'll try to be accurate. With tubing of the same composition and weight per linear foot and with the outer diameter of the round tubing being the same as the outer distance across the flats of the square tubing, the square tubing will, for the same maximum stress, support a pure bending load about a third larger than round when both square and round are loaded about an axis which passes through the centroid of the tube's cross-sectional area and which, in the case of the square tubing, is parallel to an edge.
If the bending axis of the square tubing is rotated 45 degrees, the square tubing will support a bending load about 3 times greater than the round.
Some assumptions: Square tube radii equal zero. Above is based on maximum stress encountered only, which might not be directly related to acceptable performance or to discernable component failure.
Old 02-18-2005, 04:32 PM
johnnymopar's Avatar
Love your nails! You must be a Libra
i would think that square tubing would be stronger. but, like Billy says, you have to make sure you use the right perspective. if you look at a cross section of material, using a unit of 1 for size, round tubing will have a circumference of pi, 3.14, when a square of 1x1 will have a perimeter of 4, so there is more material there. also, with the square tubing you get good strength because of the parallel sides which resist flexing, when a round tube could bend because the force is applied to the rounded side of the tubing and there is less surface area to support the pressure. maybe everybody uses round tubing because it's easy to work with and lighter because of less material?
JB
Old 02-18-2005, 05:33 PM
bracketeer's Avatar
489 Lemans
Strength
A square obviously has more surface area than a circle. A triangle is the strongest geometric configuration. The arch being second. Since a circle is basically two arches. I would have to say tubing is less likely to crush. I have no idea which would bend first.
Old 02-18-2005, 06:16 PM
adtkart@aol.com
I am not an engineer, but which is stronger depends on the type of forces. As far as the roll cages in race cars, I believe that part of the reason for the round tubing is for safety of the driver. If a body part hits the edge of a square tubing, it is more likely to be injured than hitting a round object. On the other hand if you strike the edge of a piece of square tubing with a hammer, it will take considerably more force to damage it than the flat side will take, and the edges are usually rounded. The flat sides are the weakest parts of the square tubing.
Basically, I think there are several factors to consider.
Old 02-18-2005, 06:53 PM
I've decided to go with round 1" (ID) schedule 80 for supporting my frame. . If I can figure out how to post pictures on here I will show how my frame is going to look.
Old 02-18-2005, 10:27 PM
Wiki Edits: 21
Need to go back to your mechanics of materials course. See this little essay on moment of inertia and radius of gyration of various shapes. Key sentence in this dissertation is "All things being equal, a circular pipe is the most efficient column section to resist buckling." That is why round tubing is used exclusively in high stress applications. Pound for pound it is the strongest section possible.
Old 02-19-2005, 04:13 AM
Thanks "Willys" I feel more confident now,,,,,,,,don't really understand all that jargon,,, but with an equation like that it's got to be good
Old 02-19-2005, 04:43 AM
BillyShope's Avatar
Philippines Cowboy
This is what I meant by being very careful in answering questions of this type. The author of this lecture evidently does not mean equal weight per linear foot when he says, "All things being equal...."
The area inertia of a round section, about an axis through its centroid, is #R^4/4, where "#" equals "PI." That for a square section is 4R^4/3 when "R" is half the length of one side.
If the square and round tubing is to have the same weight per linear foot, the areas must be equal. #(R^2-(R-t)^2) = 4(R^2-(R-T)^2) where "t" is the wall thickness of the round tubing and "T" is the wall thickness of the square tubing. If we solve for "T," we find T = R-(4R^2-#(2Rt-t^2))^0.5)/2.
If we then substitute this back into the inertia and area equations and solve for the radius of gyration, we find it to be, for a round tube, ((2Rt-t^2)/4)^0.5 and (#(2Rt-t^2)/12)^0.5 for a square tube. So, the radius of gyration of the square tube is some 2.3% larger than that for the round.
I don't want to accuse the author of the lecture of making a mistake. Perhaps he had some other "equal" in mind. I looked at the "home" for the site and couldn't find a way to easily contact him, so I'll leave it at that. But, when it comes to a pure bending load, the square is definitely stronger, even when using the definitions provided by the lecture site.
Old 02-19-2005, 04:53 AM
pmeisel's Avatar
Glad the Jeep is on the road
Last wiki edit: How to identify a Ford V8
For some good background on this and related matters, I recommend reading "Engineer to Win" by Carroll Smith. He relates the mechanical properties of a variety of structures, steels, fasteners, etc. back to racecar application. Amazon has it, so does Summit.
I'd break it out to do some studying on this topic but it is on a shelf behind all the spare parts I have stripped off the Jeep......
Old 02-19-2005, 05:53 AM
Willys, is not COLUMN LOADING referred to a vertical piece of material supporting a load and is not subjected to side loading? In that case, there should be no argument. Also, the essay is about buckling and not bending. In this thread application, most of our minds are keyed to side loading/impact and bending.
Trees
Old 02-19-2005, 08:15 AM
BillyShope's Avatar
Philippines Cowboy
Trees
No, Willys' point is well-taken, for the area inertia (which can be calculated using the radius of gyration) also enters into a calculation of pure bending loads. The problem is with the information cited at the U. of Oregon site. I did finally find an email address for the Associate Dean of the physics department and have informed him of the matter. If I get a response, I'll let you know.
Old 02-19-2005, 09:16 AM
Wiki Edits: 21
Trees
You are correct that side loading is another case that must be considered independently, accounting for the special loads it will encounter. A structure using round tubing ideally has all the members loaded axially, in other words being pushed or pulled, not bent. In a design like that, a 'space frame' in a race car for example, then round tubing is the lightest section for the same weight of material that you can use. However, when a structure must encounter significant side loads, a rectangular tube or better yet an I-beam shape is much stronger than a single round tube in the direction of the load. A round tubular space frame lattice could be designed to lighter but as strong as the rectangular tube or I-beam but you must then do the old cost benefit analysis and see which is more cost effective for the application. As BillyShope is showing some things are more equal than others!
