Whats up with this fuel pump return line? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-05-2010, 02:38 PM
Hello!
I've bought a Carter M6626 for my chevy 383 and there's one thing I don't get about it.
Can you please take a look at the pictures and tell me if this is what it should look like?
Am I supposed to drill it or anything for better flow. That little hole is ridiculous. Whats the purpose?
I've bought another Carter M6626 from Rockauto a while ago and it looked the same I guess I can't have such a bad luck even if its china stuff..
Thanks so far!
ID:	46594   Click image for larger version
Old 07-05-2010, 03:26 PM
DoubleVision's Avatar
It`s done this way to keep the flow and pressure up of the main output line so the bypass is restricted. It`s likely restricted in the factory pump it`s just on the inside where you can`t see it. Make sure you pack the spring cavity of the pump with moly lube or the like, SBC`s don`t have a direct oiling to the fuel pump and when it goes without lube the spring will overheat which will weaken it to the point the spring will float and not pump at upper rpms.
Old 07-05-2010, 11:18 PM
Thanks for the tip! Never heard of it before though.
I tried to blow through the return line on both models and it didn't feel like there was any restriction inside the old pump but I'll try it again to be sure.
Fuel return line (carbed) - where? McDesign Engine 5 01-24-2010 09:13 AM
fuel pump/ fuel lines bad apple Engine 2 03-12-2009 10:43 PM
Could It be my Fuel Tank / Fuel Line? 10mikeymike Engine 4 09-17-2008 02:25 PM
Help - my fuel pump is leaking KENMO Engine 10 07-01-2007 12:39 PM
efi fuel line sizing / fuel pump Blob Engine 2 09-25-2005 12:25 PM
