Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - whats ur thoughts on these rod/main bearings
Old 09-29-2012, 10:07 PM
Project89's Avatar
Project89 Project89 is offline
Originally Posted by ap72 View Post
polish the crank and replace the bearings. The additional cost isn't that much when you consider the total rebuild cost. Its best to do it right, just in case he needs to put that 3.4L off a little longer.
problem is finding a place that will polish the crank in his area.ill tell him to look around some more.
the big thing is if the engine ran fine before it came apart why would u change the bearings and not just reuse them, each rod got number punchedas to what cyl it came out of so they wouldnt get mixxed up and the bearing would go back in the same exact spot
or is my reasoning wrong on that point
