Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - whats ur thoughts on these rod/main bearings
Old 09-30-2012, 11:59 PM
Choctaw Bob's Avatar
Choctaw Bob Choctaw Bob is offline
If the money really is that short, you can always scrape the journals with a penny. That will show you how rough the crank really is. If it passes the test, clean it thoroughly, reuse the crank and bearings with the understanding that it won't be bullet proof, but I've seen a lot worse run for a very long time.
