What's wrong with this 10 bolt rear end? Caliper orientation
Here is a picture of the axle as I purchased it:
Here is a picture of the passenger's side Here is a picture of the driver's side Is this the way the 10 bolt rear end is setup from the factory? This is the way it was when I bought it. It seems weird that one caliper would be oriented one way and the opposite caliper orientated 180degrees differently. |
look at the bleeders on the calipers. If they are both on top it could be made that way.What is it out of?
I would guess the passenger side is all wrong. can it be phased 180 degrees by rmoving the caliper and mount/backing plate and re orienting it? |
I dont know what this rear end is from. I was told it was from a camaro. You can see the panhard bar mount casted into the diff. case. It is a 10 bolt with factory disc brakes which i believe is F body camaros and firebirds. It is also possi trac! |
Because braking force is always in the same direction, which is not affected my caliper orientation. |
looks like a typical 3rd gen rearend. calipers are the same part #. the backing plates have offset bolt pattern so that they cannot be bolted on any other way. my rearend came off a 96 trans am and had the same setup with 3.27 posi gear in it. all 92 to 02 camero, trans am and firebirds are the same. nice thing about it is the 2 big bolt hole for the torque bar. i mounted mine on leaf springs and added the torque bar to keep the rear end from rotating up.
I wish this rear end didn't have those two big holes for the torque bar, I AM RUNNING A 4LINK |
| S10 rear will fit but wrong bolt pattern | Rmvr53 | Transmission - Rearend | 14 | 09-24-2011 06:59 PM |
| s-10 rear caliper question | sampanjohn | Suspension - Brakes - Steering | 0 | 01-09-2009 10:45 AM |
| Rear brake caliper stuck? | frankenvette | Suspension - Brakes - Steering | 5 | 01-14-2008 04:14 AM |
| 87 Lincoln Rear Caliper Banjo Bolt Size? | sonicweb | Suspension - Brakes - Steering | 2 | 08-30-2006 01:00 PM |
| Caliper Brackets for 8" Ford Rear | Bill Ford | Suspension - Brakes - Steering | 3 | 12-30-2002 04:19 PM |
