what's wrong with the 7.5 malibu rear? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-12-2006, 11:25 PM
Augusto's Avatar
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
I have read a lot of bad things about the stock rear of my 81 malibu lately (converted to el camino by myself ) the truth is I didn't pay any attention to it until now, it hasn't braked anything yet ( I hope it won't ) it lives behind a 350 with a 144 B&M supercharger and it's hotter cam, 600 cfm holley, headers, etc. do you think I should worry about it? I have a 1977 malibu rear end sitting in my shop, I'm not sure about the size but it's the one with the squared ears at the bottom of the pumpink, is this a better choice? should I replace it? I don't race the car, it's a street tire fryer only.
Augusto.
Old 04-13-2006, 02:24 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
It depends on several things. The 7.5 lives fine in F-bodies behind some respectable torque, but they are very traction limited. The tires go up in smoke long before enough torque gets put to the 7.5.
If you put more than about 350 lb-ft to it and you get any shred of traction, there is a very good chance you'll rip the axle in to pieces. Small bearings, small ring gear, and a small casting. It was designed as a lightweight economy axle. It takes some abuse, but not where traction is involved.
If you feel saucy, go for the 8.5 from a Grand National or 442. They're not as hard to find as you might think, and if you get one from a flat-rate junkyard they're no more expensive than a Chevette axle.
The flat-eared axle you have is probably an 8.2. Its a little better than the 7.5, but if you're putting a 144 blower on things I'd go at least 8.5.
Old 04-13-2006, 03:02 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Run it until you break it. With limited traction, it might run for years.
Old 04-13-2006, 04:22 PM
Augusto's Avatar
thanks for replying, as I begin to understand the problem with this axle is in racing duty, this might explain why it has survived so far, there is the problem that I live ten thousand miles from the nearests junk yard that has american cars and must do with wathever I run into, are the 9 in ford rearends that are so desirable for cars up there the same that are found in the back of mid seventies F-150 pickups? those are plentiful here, lengthwise I don't care I own a machine shop and I'm acustomed to fabricate almost anything, we have to sometimes when parts are imposible to find. should I adapt a new axle or just use until it breaks?
Old 04-13-2006, 06:03 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
The 77 should have had an 8.5 in it and nothing else.
Old 04-13-2006, 06:45 PM
Guy Hiltz's Avatar
re:whats wrong with the 7.5 malibu rear?
I 'm fairly certain that the rear end from the 77 will not be a direct bolt in,the 9 inch from a Ford pickup would be a much better choice.
Old 04-13-2006, 10:09 PM
Augusto's Avatar
a) how good/bad is the 8.5 rear end? ( for my street supercharger )
b) installing lower gears like a 4.10 prolong life expectancy of the rear end?
Old 04-13-2006, 10:28 PM
xntrik's Avatar
If I were you I would find a Ford 9 and begin narrowing it and getting ready to install..... someday. Then when/if the old one dies, you won't be without your fun car for a weeks.
Old 04-14-2006, 08:43 PM
The '77 rear end is not a simple bolt-in, but Southside Machine made a set of conversion control arms to make the '73-'77 rear fit the G-body. They're no longer in business, but somebody might have some left-overs or some knock-offs.
Old 04-15-2006, 01:07 PM
Augusto's Avatar
thanks guys, you all are very helpful.
Augusto.
Stock rear gears on a '73 Chevelle Malibu? Malibu73 Transmission - Rearend 1 07-21-2005 05:32 PM
7.5 rear end performance question 1BADSS-10 Transmission - Rearend 2 12-16-2004 08:45 PM
57 chevy rear disc romine Suspension - Brakes - Steering 2 11-06-2004 06:43 AM
can i put 8.5 into 7.5 rear end houseing bradsregal85 Transmission - Rearend 2 02-25-2003 07:11 PM
Rear end Buffed Engine 3 10-31-2002 06:11 AM
