whats wrong with my amp power - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-26-2005, 05:34 PM
eM-K's Avatar
New Member
ok.. well after the cold winter past i look into my 84 camaro to find that a squirrel had popped out a panel underneath the dash on the passenger side and had been running around in my car as a winter home... as i looked through the ripped insulation i found a reddish orange wire casing with no wire inside about 3 or four inches long.. and it had been chewed on both sides.. now my amp that i use to power my speakers doesnt appear to be working.. do any of you have any ideas as to what this wire goes to.. i looked at the wires directly under the dash and i found nothing that matched the color.. i havnt exactly spent much time looking into this but the squirrel im guessing carried it from its original source... any suggestions as to where to look would help and save me time...
Old 06-26-2005, 06:56 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
wiring
reddish orange wire?
Red is a power wire and generally fades to pink after time. It could be from anything.
Orange wires are used for lighting; dash, map, dome, ashtray, wiper and headlight switch, radio, instruments, and glove compartment. If its an orange wire you'll figure it out the first time you turn on your headlights after dark.
Old 06-26-2005, 08:36 PM
docvette's Avatar
Wiki Edits: 12
Wire
Doc here,
My best guess is the wire that comes from the "Power Antenna" or External amp power to the power amp for low voltage switching is what you are missing...
Orange is usually the color designated for Low voltage switching.
I would also check the fuse...unless Our little Rodentia residents..had mini a pair Wire cutters, chances are you have / have had, a short in that line now, so check the line (and all around it) Before you heat it up again.
Doc
Advise on Porta Power choice meanroy Body - Exterior 7 06-23-2004 11:38 PM
Unusual Power Steering Conversion Lars Sorensen Suspension - Brakes - Steering 17 05-25-2004 02:05 PM
Power Valves Ktaves1971 Engine 1 05-11-2004 07:35 PM
Replace arm strong steering to power in your 51 to 54 Chevy car Michael Bryan Suspension - Brakes - Steering 3 05-08-2004 09:50 AM
power brakes and power steering on a '63 impala SS Benni520 Hotrodders' Lounge 2 10-14-2002 09:49 PM
