I put it back together, but I can pull it apart again. The cover is a pain in the *** because the exhaust is right in the way.What do I look for when I hold the gear and squeeze the weights? I have another 700r4 setting in the shop, I could just swap gov's. and see what happens. Whatever happened to my tranny, happened between shutting it off one night and starting it the next day (that quick).
the whole Governor turns inside the case bore but only when the tranny is in operation! the Governor should lock in when you install it with a slight twist to engage the gear, when in operation, the weights spread apart pushing the valve inside the Governor toward the gear end shifting the transmission! if the the gear is chipped,broke,or the valve IN the Governor is sticking your tranny will not shift"
I noticed on this car before I switched the guage cluster that when the wires to the guage cluster were hooked up the car shifted really radical, even at half throttle it would jump into high gear real hard. While I was waiting for my new guage cluster, I drove it a while without guages so the wires were NOT hooked up and then the tranny shifted fine. Any ideas on that?
| M II Frontend, Whats wrong here | Bluepen | Suspension - Brakes - Steering | 7 | 02-28-2004 06:48 AM |
| help with tranny munbers | notmrgoodwrench | Transmission - Rearend | 2 | 01-23-2004 09:59 PM |
| Some sound tranny advice please! | bowtieorbust | Transmission - Rearend | 18 | 12-20-2003 01:28 PM |
| Pulling motor/ tranny 66 C10 | 66thom | Engine | 6 | 10-27-2003 09:46 AM |
| 4-speed tranny making noise!!? | chevyelc81 | Transmission - Rearend | 6 | 08-04-2002 07:23 PM |
