Brian...I think we lost a little bit of the art when we went from lacquer primer to high build...lacquer primer didn't fill that well and your body work needed to be straight...when high build came out, and I'm old enough to remember, most body men hated it...you had to clean the primer gun after using it, it had to sit overnight before sanding, the early 2K primer sanded harder than lacquer primer, lacquer primer dried quick, sanded like powder and could sit in the paint pot for however long you wanted it to. How could a flat rate body man make a decent living...and then it was explained that they didn't need to finish there bodywork as nice because the primer would fill 80 grit and even 40 grit scratches. Of coarse we know what eventually happens, sinking, sand scratches paint dying off etc. but, like you mentioned, how many body men or painters see their work 1 or 2 years after it leaves the shop.
Ray
