Whats your opinion of this befor I cut it. - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-30-2005, 02:08 PM
Ratchet's Avatar
Last journal entry: Ontario Camaro Nationals 2008
This is a model of the billet aluminum emblems I am making for the project car. What do you think of the look. is there anything I should change. Sketches or modifications to the picture below would be appreciated.
Old 03-30-2005, 02:53 PM
Bee4Me's Avatar
Problem Child,Hard Case
Last journal entry: Strangest job I've ever done
Nice,
Not sure what your looking for exactly but it seems your on the right track.
Old 03-30-2005, 02:57 PM
daimon1054's Avatar
What's a ZZD? Look like it will be a good looking emblem but I hate stuff I have to wax around
Old 03-30-2005, 05:23 PM
Ratchet's Avatar
whats a ZZD
We named our project car ZZD it stands for Zig Zag and Drag. We wanted to build a hot rod that was an all around fun car to drive as well as look good.
Old 03-31-2005, 06:40 AM
Beenaway2long's Avatar
or Jeff, or Doc, or...
Last journal entry: Results of the Camaro
The posts on the backside will definately add to the raw stock thickness , and add to machine time. Perhaps locating a threaded boss behind the thickened letters, and use a screw/loctite from the backside would be cheaper/easier.
Old 03-31-2005, 11:34 AM
GMW GMW is offline
I'd lose the studs all together and apply it with an adhesive. Thats how they are all attached today.
Old 03-31-2005, 10:27 PM
Ratchet's Avatar
GMW .....The Posts on the back push into tappered nylon sleves that are mounted in the ground effects. This is the stock method for installation. But since we will have so much invested in them we may also use your idea of the adhesive just to make sure they don't walk away.
We altered the font a little bit and went ahead and cut a couple today.
Here are a couple of pics as machined
They took about 2 hours each to machine.
Old 03-31-2005, 10:33 PM
Ratchet's Avatar
We got a little anxious to see what they would look like with a black background so we sprayed some black primer on them and wiped off the face of the lettering.
Here is what that looks like.
All suggestions on how to finish them for real welcome.
"Basics of Basics" Sectioning a Body MARTINSR Body - Exterior 7 11-24-2008 12:04 PM
Question about removing roof 86caprirs Body - Exterior 3 03-27-2005 12:21 PM
Motor&Dash cut off & right back on worknprogress72 Electrical 2 04-22-2004 05:34 PM
cut brake line while cutting out floor 59countrysedan Suspension - Brakes - Steering 20 02-06-2004 09:07 AM
