-   -   wheel adapters (http://www.hotrodders.com/forum/wheel-adapters-209922.html)
alkey 12-07-2011 05:58 AM
wheel adapters
does anyone know if wheel adapters are still available? i would like to get an adapter so i could carry one spare tire in case of a flat.
matts37chev 12-07-2011 07:15 AM
yes they are
what are the two bolt patterns you are dealing with?
i would think you would want the wheel to match the front pattern and use the adapter for the rear (more space in the rear to move the wheel out)
is this what you had in mind?
alkey 12-09-2011 06:41 PM
wheel adapters
5 on 5.5 to 5 on 4.75 are the bolt patterns
matts37chev 12-09-2011 07:44 PM
here are a couple
they are 1.25" thick
cobalt327 12-09-2011 08:01 PM
Be sure the spare has adequate clearance for the brakes and will clear the front steering, body and suspension on both ends. The spare should provide enough height that will keep any part of the vehicle from hitting the road, even if IT is flat.
Studedean 12-10-2011 04:03 PM
i got front and rear on ebay. machined as requested. went from ford to chevy. and up to 3" thick
alkey 12-12-2011 04:18 PM
wheel adapters
Thanks everyone for information.
