Start a tech article on any subject...
...hundreds of hotrodders help build it into a comprehensive resource.
Fresh wiki articles that you can add to: Air suspension on a front solid axle, Basic stuff for newbies, Building a new shop, Ceramic insulation, Electric fuel pump mount, Engine and transmission mounts, Freeing a stuck engine, Gasser, How to check driveline angle, How to make a vacuum power brake bleeder, How to safely cut steel with a torch, Improving fuel economy, Narrowing a rearend, Patching a body panel, Quick-disconnect rear mount battery, Reducing vehicle weight, Stereo installation, Stripping paint, Valve spring setup, and many more...
Or, start a new article.
Hotrodders Bulletin Board > General Discussion > Hotrodders' Lounge > Introduce Yourself
  #1
Old 09-28-2004, 06:49 AM
ikeaguirre14 ikeaguirre14 is offline
New Member
wheel adapters
im a 1st semester body and paint student and we are to come up with a project. we are learning welding and since i just got some new rims ,that dont fit, does anyone have the dimensions or a site that does have dimensions for wheel adapters. so i can fabricate my own. my instructor is getting me the correct steel to use so all i need is a dimension drawing.
Old 09-28-2004, 10:45 AM
poncho62's Avatar
poncho62 poncho62 is offline
Moderator
 poncho62's barnstar
Wiki Edits: 5
re: wheel adapters
welcome...............better to post your question in the "General Rodding" forum..You will get a better response.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
