Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - wheel adapters
Thread: wheel adapters
Old 03-27-2008, 05:14 PM
MAUSS MAUSS is offline
Since you already have the Escort wheels, a simple solution would be to have the Chevette axle flanges re-drilled to the Ford bolt circle, between the old studs. Press out the old studs and press in new ones (long studs if you want to run a spacer). You'll want to check the lug nut style too, since the nut seats might be different on the aluminum wheels that the old steel wheel lug nuts. Filing the holes would be a very bad idea.
