Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Wheel Backspacing
Old 11-09-2002, 03:27 PM
Canzus's Avatar
Canzus Canzus is offline
a red wool sock on his dinger
Post
>1) O" backspacing means that there is a equal >amount of spacing on each side of the >wheel...example...3.5 on the front, and 3.5 on >the rear.
No, 0" back space the rim would line up with
rear face of the mounting surface, 0" offset
is what you're discribing...
>2) Positive is more on the curb side of the >wheel, negative has more on the frame side.
Tough to tell on this one, as I've seen them
Quoted both ways...
>Example: If you have a 15 X 7 wheel with 4" >backspace ...it is a 0" offset wheel. The reason >is that a 7" wheel is 8" at the widest point and >7" between the beads of the tire when mounted.
A 7" wheel *MIGHT* be an inside measurement, but
it won't be 8" wide, 7.5" maybe, so it'll be a
4" backspace and a 1/2" offset...
It's best to order wheels using the backspace
measurement...
Just to add to the confusion, go here...
<a href="http://www.angelfire.com/ar/dw42/offset.htm" target="_blank">http://www.angelfire.com/ar/dw42/offset.htm</a>
Steve & the Rockette...
Too many to list...
[ November 09, 2002: Message edited by: Canzus ]</p>
