wheel backspacing and offset 93 caprice classic - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-30-2013, 07:31 PM
Hey im not on here often, sorry but need some advice. i have a 93 Chevy Caprice Classic and want to run a different set of wheels. None of the rims I saw I liked besides a set I saw on Summit. The bolt pattern is the same as the wheels but I believe the backspacing may be different. The backspacing for the wheels I want are 4.25 in. backspacing. Just wanted to know what I had to do if anything to make it work.
Thanks.
Here's the link to the wheels
http://www.summitracing.com/parts/pc...873f/overview/
i know they may be rock crawling rims but i like the design.
Old 05-01-2013, 10:39 PM
RWENUTS's Avatar
What's the backspacing on your stock rims?
Old 05-02-2013, 09:42 AM
Haven't had time to check but I think it's anywhere between 4-5 in. I just wanted to make sure that I had enough clearance even though the rims aren't designed for my car.
Old 05-02-2013, 09:44 AM
I'm running the stock steel rims right now
Old 05-02-2013, 10:07 AM
RWENUTS's Avatar
You'll just need to do lots of measuring. Your stock b/s is likely close to 4".
What size of tires do you have now?
What Size of tire do you wanna run?
Old 05-02-2013, 08:16 PM
I have 215 70 15 and possibly going up to a 255 50 or a 245.
Old 05-02-2013, 09:37 PM
RWENUTS's Avatar
You'll still need to confirm your stock wheel width and backspacing then determine what tires will work. I found some info on Impala SS wheels which someone used on their Caprice and they had a b/s of 6 inches and fit.
Sometimes it's easier to get the tires you want mounted on your stock rims, mount them then check for clearance problems and buy rims that will work. Could save a bunch of money that way.
Old 05-02-2013, 11:12 PM
Thanks for the advice, I think that could work. I could just repaint the steelies I have to get a decent look out of them for right now. I was looking for a set of the 94-96 impala ss wheels but they are kinda hard to find
Old 05-03-2013, 12:04 AM
RWENUTS's Avatar
Really! What about these? Likely worth the drive.
Impala SS wheels
Old 05-03-2013, 12:29 AM
Hahaha did not see those. I'll check them out tomorrow. Thanks man.
putting rims on a 1970 impala, backspacing and offset question? logic-ali Suspension - Brakes - Steering 1 12-12-2010 03:10 AM
Rim offset for classic Chevy truck?? DV8 General Rodding Tech 6 06-15-2006 10:08 PM
Wheel backspacing??? 84Z General Rodding Tech 2 01-11-2004 02:28 PM
Wheel Backspacing Bill Ford Suspension - Brakes - Steering 2 11-09-2002 03:27 PM
Wheel Backspacing birdman Suspension - Brakes - Steering 1 10-28-2001 01:19 AM
