Wheel bearing grease seal - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-20-2004, 09:58 AM
Hey all,
So I've got some 78 cougar spindles (disc brakes) that I'm rebuilding before putting them into my 64 galiaxie.
Right now I'm cleaning the rotors up so that i can send them out to get re-surfaced.
For some reason I can't seem to get the grease seal off the back of the rotor to get the inboard bearing out of there. Can't even slide a knife up under the edge of the thing? What am I missing?
Old 03-20-2004, 10:28 AM
Hey all,
Old 03-20-2004, 12:40 PM
poncho62's Avatar
Wiki Edits: 5
Put a aluminum rod down through the front of the rotor and give it a smack. If it breaks the bearing and seal, which it won't, they should have been replaced anyways.
Old 03-20-2004, 08:38 PM
Tap out bearing an seal together
I have had this problem and what I normaly do is come in from the opposite side with a piece of wood, put it against the bearing, and tap the bearing and the seal out together. This works most of the time but I did have a hub one time that I had to use a hydrolic press on to get the bearing and seal out. You want to use the wood so you don't damage anything tapping it out. Don't go in there with a screw driver. Hope this works for you.
