Wheel bearing help - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-12-2012, 09:33 PM
Mutt's37Buick's Avatar
Wheel bearing help
I know this is a long shot, but I'm hoping someone can help.
This my first hot rod build, so sorry if this totally off the wall.
I bought a '95 Roadmaster as a donor car and I'm trying to use the front brakes & rotors in wiki conversion similar to:
http://www.crankshaftcoalition.com/w...ension_upgrade.
In that wki they use a drop spindle from CPP that matches a '63 Pontiac bearing surfaces. This spindle is sold by CPP in a kit that uses a '70s Chevelle 11" Rotor which matches the bearings of the '63 Pontiac. My '95 Roadmaster has 12" rotor with a hub rotor depth that is almost the same and matches the inner bearing of the other two rotors. The '95 Roadmasater outer bearing is larger though. The Chevelle/Pontiac uses an outer bearing with 1.781 OD, .76ID, .61 depth. The '95 Roadmaster uses a outer bearing with 1.9687OD, .8437 ID, and .690 width.
1) Does anyone know if there is a bearing that has ID of the '75 Chevelle and OD of the Roadmaster?
2) If not, is it possible to add a sleeve to the inner or outer bearing diameter that will allow the '95 rotor to be used on the Chevelle/Pontiac spindle?
Thanks
Old 03-12-2012, 10:45 PM
evolvo's Avatar
This should keep you busy for a while
http://www.timken.com/EN-US/products...on_Catalog.pdf
Old 03-13-2012, 08:37 AM
Thanks for the info. A sleeve on the spindle seemed like the best option if there is no bearing avail. Could shrink the spindle with dry ice for a tight fit.
I'll also have to design a bracket to hold the calipers in the correct position.
DiscbrakeMike has said he would develop the new bracket for me, but it does not seem like rocket science so I might try it on my own.
1) Has anyone used DiscbrakeMike kits, and were they high quality.
2) Has anyone out there designed a caliper mount bracket and are there any tips you can share like material, heat treat req'd..etc.
Thanks
Replace none abs wheel bearing with abs bearing jrmz28 Hotrodding Basics 5 04-22-2011 07:14 PM
Wheel bearing.... SouthernRodder Suspension - Brakes - Steering 1 12-30-2007 08:14 AM
Wheel bearing repair ? jamn50 Suspension - Brakes - Steering 2 12-22-2004 07:23 PM
Wheel bearing repair ? jamn50 Suspension - Brakes - Steering 1 12-22-2004 08:14 AM
wheel bearing? APACHEMAN Suspension - Brakes - Steering 1 02-09-2004 12:29 PM
