Wheel bearing repair ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-20-2004, 08:20 PM
I have a 2000 GMC full size 1/2 ton 2 wheel drive pick-up. The front wheel bearing has play in it. There is no outboard dust shield or castle nut for end play adjustment. I removed the bearing assembly from the spindle, a dust shield is on the back.Can't figure out if the bearing is servicable. Looks like what holds the bearing in place is rolled/formed so it can't be removed. Any clues? Thanks. Cary.
Old 12-22-2004, 08:14 AM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
These bearings are not serviceable they have to be replaced with a hub bearing assembly.
Steve
