Wheel bearing replacement - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-10-2009, 07:48 PM
Hey guys got a quick question here not regarding a hot rod but I'm asking anyway because this site and the people who use it are full of knowledge! I'm wondering what special tools I will need to replace the rear wheel bearings on a 1998 subaru forester All-Wheel-Drive. I haven't done wheel bearings in quite some time and this being my moms car I told her I would do it for her so I don't want to be eating my words. It looks fairly straight forward but once I get in there I'm sure I will need pullers and punches and stuff, if anyone could give me a list I'd really appreciate it. Again I know this is no hotrod but everything out there works off the same principles, right!
Thanks,
Keith
Old 09-11-2009, 07:30 AM
BOBCRMAN@aol.com's Avatar
Most of these type vehicles require that the center hub is pressed from the bearing. Then a snap ring removed from the bearing OD. The bearing pressed out. Opposite to re assemble. A press and heat is required on Michigan cars..
HF English Wheel cboy Garage - Tools 40 01-03-2017 01:44 PM
"tapered" rear axel bearing question powerrodsmike Transmission - Rearend 3 08-10-2007 05:47 PM
not a hotrod question, changing a wheel bearing TailGater Suspension - Brakes - Steering 3 04-18-2007 07:51 PM
what is best wheel bearing grease? NorthStar Suspension - Brakes - Steering 1 05-17-2005 09:07 PM
Wheel stud replacement method jpd37 Transmission - Rearend 3 06-18-2003 12:07 PM
