Wheel cylinder problem? cylinder helpppp!!!
Hello
Heres the deal. The 1972 elcamino has drums in the front.
The front end suddenly started pulling left alittle yesterday so i decided to take a look at the brakes and front end. the rotor was stuck on the brakes and was finally removed to see the brakes were extended all the way out like the brake pedal was to the floor. the brakes were shot and the rotor had a small groove starting in it. i turned the rotor and got new brakes but the cylinder wont seem to go in like its stuck in place i tried several times to push it together with no luck. i inspected the brakes and compared them to the old they are the same brand and model so im guessing the cylinder is at fault?
Hello
