Wheel cylinder problem? brake lock up? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-30-2005, 07:33 PM
Wheel cylinder problem? cylinder helpppp!!!
Hello
Heres the deal. The 1972 elcamino has drums in the front.
The front end suddenly started pulling left alittle yesterday so i decided to take a look at the brakes and front end. the rotor was stuck on the brakes and was finally removed to see the brakes were extended all the way out like the brake pedal was to the floor. the brakes were shot and the rotor had a small groove starting in it. i turned the rotor and got new brakes but the cylinder wont seem to go in like its stuck in place i tried several times to push it together with no luck. i inspected the brakes and compared them to the old they are the same brand and model so im guessing the cylinder is at fault?
Old 05-30-2005, 08:22 PM
poncho62's Avatar
Wiki Edits: 5
Replace the cylinder and rubber flex line too........Chances are that it has deteriorated and closed up or has debris wedged in it. I would do both sides to be on the safe side.
Old 05-31-2005, 01:11 PM
Ok i went to get another brake cylinder and none i have found will work.i tried alot of places and tried npd and they have a different one as well. the cylinder is 2 and 7/8 boot to boot. i was given a 3" and it would not work. the brakes would not close enough to clear the rotor even fully adjusted in. the brakes are hitting the cylinder. i compared the cylinder to the other front brake and it is the same 2 and 7/8. the brakes are also the exact replacements for the shoes so the brakes are not the problem. im thinking ill have to rebuild the cylinder but there is no rebuild kit for the style i have. im going to order the bendix brand and see if it will work. never thought a cylinder could shrink over time and the new replacements grew to big lol
Old 06-01-2005, 10:21 AM
johnsongrass1's Avatar
Race it, Don't rice it!
IF you bought the cheapest shoes they had with the 1 year or lifetime warranty my guess is the pad material has been laid on so thick to reduce the No of returns you may not get it into the rotor without taking a bunch off the ID. As long as the cylinder bores are the same size the rebuild kit will work from another cylinder. Just change the rubber cups.
Old 06-01-2005, 07:35 PM
thanks poncho and johnsongrass!
yes the cheap brand of cylinders wouldnt work out on my model but the bendix work fine, what is strange is the rest are wagner brand but i cant find one of those anywhere although the bendix as just as good. dont buy the cheap stuff im learing!
brake booster vacuum problem spankthru Engine 1 06-18-2003 07:57 PM
Somebody stop me!!!! Mrfixmaster Suspension - Brakes - Steering 35 01-29-2003 06:45 AM
Bleed Wheel Cylinder?? Dave E Shank Suspension - Brakes - Steering 6 01-03-2003 03:49 PM
brake problem 65galaxie500 Suspension - Brakes - Steering 3 10-22-2002 01:21 PM
front disc brake wheel cylinder??--bleeders Tom34ford Suspension - Brakes - Steering 2 06-03-2002 04:02 PM
