Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Wheel cylinders
Thread: Wheel cylinders
Old 12-03-2012, 12:58 PM
vinniekq2's Avatar
vinniekq2 vinniekq2 is offline
all of the above plus you can power bleed the system if you think you and your bleed partner are missing some air. do it twice.Make sure fluid is coming out clean before you tighten bleeder.
You can also use your finger over bleeder opening to prevent air being drawn back in if you must bleed with out power bleeder and you are not sure about partner lifting the pedal too quickly.
