Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Wheel cylinders
Thread: Wheel cylinders
Old 12-03-2012, 04:32 PM
Oilyrascal Oilyrascal is offline
Originally Posted by poncho62 View Post
You need a proportioning valve.....Plus, that 86 MC is made for disk brakes on front.
As for the wheel cylinders, if they are not leaking and they push out the brake shoes, they are good.
Can you elaborate as to why I need a proportioning valve, the original set-up in the 86 did have one, I have considered this all along as a possibility to a problem and have posed this very same question on other forums and the suggestion of needing one has been blown off.
I have also considered the master as being an issue because as you say it was made for disks up front, again I have suggested this very same question to others and have been blown off. Please elaborate if you can.
I know what a proportioning valve does, just trying to understand why I may need one here.
