Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Wheel cylinders
Thread: Wheel cylinders
Old 12-03-2012, 04:45 PM
Oilyrascal Oilyrascal is offline
Originally Posted by vinniekq2 View Post
all of the above plus you can power bleed the system if you think you and your bleed partner are missing some air. do it twice.Make sure fluid is coming out clean before you tighten bleeder.
You can also use your finger over bleeder opening to prevent air being drawn back in if you must bleed with out power bleeder and you are not sure about partner lifting the pedal too quickly.
I did bleed many time with a power bleeder. I am wondering though if air was being drawn in around the threads of the nipple, I wonder if teflon tape would hold up against brake fluid and seal those threads?
