Wheel hop in 10 pickup - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-14-2012, 10:29 PM
spinn's Avatar
Wheel hop in C10 pickup
Hello, My 85 C10 vortec performer cam 305 has a wheel hop problem. The rear 8.5 has 3.73's and stock leafs with new reflex shocks. The dynamic 3000 stall allows for some nice launches similar to a grand national. The problem , the wheels do not spin nice, sometimes hop violently. What are my choices to control this without using a pinion snubber type device?
TRaction bars ? Repacking the leafs? Something that im not familiar?
In chicago the only place that repacks the leafs is grants spring on cicero and 135th. Suggestion and recommendations welcome.
Old 05-15-2012, 04:33 AM
spinn's Avatar
Do i need cal tracks? Like below, or will repacking the stock leafs help?
http://img.auctiva.com/imgdata/9/4/7...2601037_tp.jpg
The suspension is stock with a stock ride height.
If standard lakewood universal bars will help, how do they clear the bottom mounted flange? A spacer and longer u bolts.
A link to pictures of some installed would help me.
Old 05-15-2012, 07:35 AM
S10xGN's Avatar
Gotta love a turbo!
Cal-trac's will work. With a set on my S-10, I ended up dropping the spring pack to just 2 leaves.
Russ
Old 05-15-2012, 02:16 PM
spinn's Avatar
Thank you for your reply. My knowledge is a little weak on launch mechanics. What is the benefit of reducing the leafs in pack?
How far down do Cal tracks hang under the flange ? Will they contact bumps and such?
Old 05-16-2012, 07:10 AM
S10xGN's Avatar
Gotta love a turbo!
Reducing the spring pack allows the bars to "work" better. I don't carry anything in the bed, so the ride feel is unaffected. My pix will answer your other questions...
Russ
ID:	65398   Click image for larger version
ID:	65399   Click image for larger version
Old 05-16-2012, 02:12 PM
spinn's Avatar
Looks nice and tight.
A turbo S10? Ride on.
You think that setup will improve my wheel hop? Most think a 305 with vortec 906 heads and performer cam/intake is a waste, but its pretty fun.
Old 05-16-2012, 04:44 PM
Last wiki edit: How to make a custom dashboard
Last journal entry: Been a long time
Wiki Edits: 4
I am running Cal Tracks in my 01 Dodge Dakota R/T. Decent amount of engine and tranny mods, no wheel hop. Have had them for going on 8 years with no issues - sometimes they make a little noise when turning onto steep driveways, but otherwise you won't even notice them there until you get on it.
Old 05-16-2012, 07:56 PM
I have a set of caltracs on my 58 Chevy PU. They hook up! If they have springs for your application I would buy them at the same time. Or you will need to take a leaf or 2 out as said before, they really stiffen the spring rate a lot.
Wheel Hop Dougie Suspension - Brakes - Steering 13 03-30-2011 02:28 AM
wheel hop tsmall114 Suspension - Brakes - Steering 1 11-09-2009 07:38 AM
Wheel Hop Bryan Phipps Transmission - Rearend 3 12-17-2006 02:54 PM
wheel hop cruiser22 Suspension - Brakes - Steering 1 06-14-2006 02:22 PM
wheel hop camino_man Suspension - Brakes - Steering 1 04-30-2003 04:20 PM
