Wheel Hop - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-17-2006, 11:01 AM
Wheel Hop
I recently swapped a 10 bolt with a twelve bolt in my '72 elcamino. I went from an open set up to a GM limited slip set up. The rearend wheel hopps on wet pavement, I don't know what to do next, thanks.
Old 12-17-2006, 11:12 AM
GMCTRUCKS's Avatar
Wheel hop
Maybe traction bars im sure other members know more than me and will help you soon. Good Luck!
Old 12-17-2006, 02:09 PM
red_rider52's Avatar
DriveItLikeItsSupostToBeD riven
I went from a open rear to a limited slip in my 67 firebird and had the same problem anytime the tires would spin i would get wheel hop. I put a set of traction bars on and never got wheel hop again. Cheap easy fix if you don't mind the look of them.
Old 12-17-2006, 02:54 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Lakewood has a product named "No Hop Bars" that work real well for me.
I used them on a 68 SS 396 Chevelle I had in high school ( early 1970's)
ElCamino uses a Chevelle design chassis.
Early Ford Wire Wheel Tech wheelkid General Rodding Tech 1 06-02-2006 12:15 AM
wheel hop freerider99 Suspension - Brakes - Steering 6 07-15-2004 10:41 AM
wheel hop... 1997 F250 Trav Suspension - Brakes - Steering 3 02-11-2004 07:38 PM
Eliminating Wheel Hop F-1Rodder Suspension - Brakes - Steering 5 06-13-2003 12:03 PM
El Camino Wheel Hop wheresyamotor Transmission - Rearend 3 01-29-2003 05:39 AM
