Wheel Hop - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-17-2011, 09:41 PM
Wheel Hop
Assuming everything else is equal, is wheelhop worse when a tire spins (ie narrow stock tire) or when you have a wider tire with better grip?
Old 03-17-2011, 10:47 PM
327NUT's Avatar
I think this is in the wrong section....suspension maybe?
Old 03-17-2011, 11:27 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
If the tire's spinning you shouldn't have any hop.
Moving to the suspension forum.
Old 03-17-2011, 11:49 PM
kleen56's Avatar
Out of round tire, separation of the belt on a tire, bad worn out leaf springs, all the above?
Old 03-18-2011, 04:08 AM
sqzbox's Avatar
My pipes are my music
It's all bad no matter. Get a set of traction bars if your having problems or, keep your foot out of it before you cause real damage to your axle or suspension.
Old 03-18-2011, 07:51 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If the tire immediately spins and there is a total loss of traction, the wheel hop either will not occur or will be slight. It's when the traction is good enough that the pinion can climb the ring gear- causing the spring to wrap up in a "S" shape until the spring overcomes the resistance and snaps back into its normal shape- that wheel hop will ruin traction and even break driveline and suspension parts.
Old 03-18-2011, 08:33 PM
Silverback's Avatar
Boost Retard
if it just spins it will not wheelhop, but if it wheelhops it looses traction and spins...
What's worse... a bigger, stickier tire will hop harder and grab harder causing more damage, unless you get to the point where it's big and soft and absorbing a lot of energy, but then typically it won't hop.
either way, it's usually a sign that something is loose or broken, and will typically break things much worse, so it needs to be dealt with.
Old 03-20-2011, 08:45 PM
I was just curious because Im thinking of keeping stock skinny tires on for a total sleeper look, but wondering what will happen if I get on it knowing I'd get wheelspin. So I was wondering how wheel hop would play out.
Old 03-28-2011, 03:42 PM
Silverback's Avatar
Boost Retard
again, you shouldn't get wheel hop if everything is working correctly...
Old 03-28-2011, 04:49 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
When I have had wheel hop, it was when the tire was spinning, then started gaining traction when it started to hop. I have had it on coil spring and leaf spring cars with fairly wide tires.
Back to the last question, If you are running a skinny tire, you will lessen the chances of having wheel hop.
Old 03-29-2011, 03:43 AM
sqzbox's Avatar
What kind of car we talking about?
Old 03-29-2011, 03:49 AM
3rdmember
air shocks?
that's what usually did it....
Old 03-29-2011, 02:53 PM
Silverback's Avatar
Boost Retard
air shocks, worn out/too soft bushings, loose stuff, bent stuff, soft IRS with too much power (I've had a bad case when I put a positive dispacment blower on a G35 that just had hopeless wheel hop after that)...
Generally, like I already said, something is wrong allowing something to move in a direction it shouldn't to cause wheel hop...
Old 03-30-2011, 03:28 AM
sqzbox's Avatar
Only one way to find out, mash on it! If the wheels hop, get some traction bars or some links that connect to the frame that aren't so noticeable. If they spin without wheel hop your wasting power to the ground. Sleepers don't win smoking tires.
old ET mag wheel value? fast68 Hotrodding Basics 4 11-03-2009 03:33 AM
hubless wheel: Swiss company re-invents the wheel Jon Hotrodders' Lounge 28 03-13-2007 02:36 PM
recovering a grant challenger wheel and painting the wheel itself gothrod87 Interior 0 09-14-2006 08:02 PM
Are chrome wheel plugs supposed to be loose in Weld wheel? shockers69 Hotrodding Basics 4 03-01-2006 11:05 AM
Wheel Hop - 66 GMC Siggy_Freud Suspension - Brakes - Steering 1 03-03-2005 01:07 PM
