wheel hop - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-18-2011, 09:47 AM
Last journal entry: 93 chevy pickup
wheel hop
My 93 chevy pickup has extreme wheel hop under full acelaration .I would like to use a traction bar like the ones cal trac makes but they are to expension for. Ialso dont want to use the old style slapper bars .They hang down to much . I would really appreciate some suggestions . My pickup is a c1500 2 wheel drive . 350 engine,cam headers . moderatly lowered Thanks
Old 12-18-2011, 09:50 AM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
is the rearend on top or below the spring pack?
Old 12-18-2011, 09:51 AM
Last journal entry: My Last Hot Rod
stagger your shocks
mount one forward and the other rearward like Ford done to cure that problem.
Old 12-18-2011, 10:04 AM
The rear end is below the spring pack.
Old 12-18-2011, 10:11 AM
kleen56's Avatar
There could be several factors. Tires and cause wheel hop if the tread is separating, I had the same problem after lowering my 56 Ford. Depending on how low your going. Lowering the car will change the pitch angle of the rear end. What I did was I raised the front hangers about an inch on the frame and that allowed me to retain the correct pitch angle for the rear end, driveline. My method will lower the truck another 1/2 inch or so... Another option is to purchase wedges which come in various degrees of pitch. Those can be placed underneath the rear mounts (ubolts) to correct it as well. After I did that, I had zero wheel hop. Wheel hop is common when you remove leafs to lower the rear. The leaf become weaker due to less leafs as well. Here's a good article that may help you understand what is going on.
http://www.competitionengineering.co...s/chassis2.asp
Old 12-18-2011, 10:15 AM
Valkyrie5.7's Avatar
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
Whats the rate on the shock absorbers in the rear? I thought I was being clever when I was towing some rather heavy loads that were eating stock shocks. I decided to replace them with some rather stiff coil springs and reinforced the spring perches on the frame. I had horrible wheel hop to the point where it practically beat my dash to pieces when I wasn't towing a load.
I should mention that I have 2wd 96 C2500 lowered 3"/4"
Old 12-18-2011, 10:24 AM
I dont no the rate of the shocks . They are new monroe gas shocks
Old 12-18-2011, 10:46 AM
& matts38chev
you can make a bar that goes from the u-bolts to the front spring hanger bolt something like this looks pretty simple
Old 12-18-2011, 11:09 AM
Thanks so much for the information. I will call tomorrow to see if this will work on a 2 wheel drive .
Wheel tub fab help PT64 Body - Exterior 0 10-04-2008 04:27 PM
hubless wheel: Swiss company re-invents the wheel Jon Hotrodders' Lounge 28 03-13-2007 02:36 PM
recovering a grant challenger wheel and painting the wheel itself gothrod87 Interior 0 09-14-2006 08:02 PM
Are chrome wheel plugs supposed to be loose in Weld wheel? shockers69 Hotrodding Basics 4 03-01-2006 11:05 AM
Wheel Hop - 66 GMC Siggy_Freud Suspension - Brakes - Steering 1 03-03-2005 01:07 PM
