Wheel hop with rear end 1952 chevy truck - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-18-2013, 06:19 PM
We are working on my son 52 chevy truck---Just put the engine in before Christmas 406 SBC-iT'S RIGHT AT 500 HP-WE are running a 10 bolt 8.5 pos rear end 373 gears-It has leaf springs-We are having wheel hop from a dead stand still.From a roll it's spinning the wheels but no wheel hop.The truck had been lowed.The truck was sit up years ago with this rear end before we got.we had a 350 in it before it run great like this but now I see I don't think this rear end can handle the HP.Like to get this one to work if we can for now.Got a lot of $$$$ in the engine,And money is getting a little funny you now.Need some ideas
ID:	70715   Click image for larger version
ID:	70716   Click image for larger version
Old 01-18-2013, 06:34 PM
BOBCRMAN@aol.com's Avatar
cheap cure is to clamp the leaves of the spring front halves together.
Old 01-18-2013, 09:59 PM
aosborn's Avatar
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
I agree...
Old 01-19-2013, 06:05 AM
Do you think the 10 bolt will hold up or do you think I need to be looking a 9'' FORD FOR LATER ON
Old 01-20-2013, 07:40 AM
496CHEVY3100's Avatar
Big boys wear Bowties
Last journal entry: ,
As others said leave clamps work,also jegs have old style round traction bars ,look great ,i have a 53 chevy p/u with a 496 big block alum heads ,corvette tripower.Well ever 500 hp ,I cured my wheel hop by lowering pinion angle which preloads it Iam running a 10 bolt at present will be changing to indepengent suspensiom rear 74 vette dana 44 ,newer models have a dana 35 ,will have to see how yhis works,Good luck Good Lookung Truck
Old 01-20-2013, 04:17 PM
I had the old "slapper" bars that were welded to the lowering blocks with a bracket off to the side with the rubber bumper under the spring. I have to tell you, ZERO hop. That sucker hooked up big time.
Old 01-20-2013, 05:56 PM
lakeroadster's Avatar
Hot Rods are Built, not Bought
What size tires are on the truck? The 10 bolt should be fine short term as long as you don't have wide sticky tires.
Now if you are trying to plant the 500 HP you should be shopping for something a bit stouter. A 12 bolt would be nice or, as you stated, a 9" Ford.
Old 01-20-2013, 07:30 PM
Martin looks like a Redlight ,Just joking good launch dont look like sedan will catch up,
Old 01-20-2013, 09:04 PM
Yep, good times at the drag strip, it's all gone and we have a Lowes, toys R us and Starbucks there now.
Old 01-20-2013, 09:29 PM
running P255/60R15 on the rear right now may have to drop down size a little but we like the way the tires fills up the big fender-same tires that was on it when we had the 350 in it.I'm going out the the other shop and check on the 68 El Camino I have and see what the rear end in it is I had forgot all about that one.I hope it's a 12 bolt but don't know.Like to Thank everyone for the help and replys still need the help
Old 01-24-2013, 04:37 PM
71nova355's Avatar
that ten bolt will hold up to 500 hp. unless your just launching it over n over everyday like at the strip. You just need some suspension or chassis help. like traction bars, caltracs, better springs, spring clamps, 4 link, or the like. whats your plans overall with the truck? weekend warrior, daily, street strip, strip only? I bet we can help you fix the issue for what you want. does it do this under hard braking too?
Old 01-24-2013, 07:16 PM
the truck will be a drove anytime truck-it will be run on the strip,and turn on the streets a lot-under hard braking when it comes out in when it wheel hopping bad from a 10-15 mile roll it's braking the wheels lose and spinning but it moving on down the road.
Old 03-05-2013, 09:29 PM
Truck's at muffer shop--flow masters muffers-
ID:	72086   Click image for larger version
Old 03-05-2013, 10:47 PM
zmaxmotorsports's Avatar
On my 50 chevy pickup I had as a kid with bbc and 4 speed We used a 12 bolt rearend out of a 70 chevelle that had trailing arms origionally.
I used the existing mounting mounts on top of 3rd member to run homemade control arms to a cross member I added to frame,then I mounted the axle on top of the stock reworked truck springs.
That truck would pull the front tires off the ground 2" and just launch like a damn motorcycle,no tire spin problems.
Cty sheriff lived down the hill from me,we talked regularly!
1952 chevy wheel options leadsled7 Hotrodding Basics 3 01-24-2013 07:29 PM
1955.2 Chevy Truck LS1 Front Ford 8.8 Rear 4 wheel Disc fasteddy51 Suspension - Brakes - Steering 1 07-13-2011 03:16 PM
1952 Chevy 3600 rear end Crakums_GT Transmission - Rearend 15 12-12-2009 07:35 PM
What size is my 1952 chevy rear end? ekubota1 Transmission - Rearend 8 04-15-2007 09:28 AM
Ford 9" rear end vs stock 89 chevy truck rear end jimmy p Transmission - Rearend 2 12-07-2005 03:28 AM
