Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - wheel hopping 69 camaro
Old 07-27-2009, 08:10 PM
ericnova72's Avatar
ericnova72 ericnova72 is offline
More for Less Racer
Originally Posted by 302 Z28
. The only down side was after a while the snubber started bending the leaf spring where it contacted it.
This is the reason I said that Comp Engineering is the only company I've seen that makes these correctly. The snubber should hit DIRECTLY UNDER the front spring eye, and not out on the leaf so it doesn't try to bend the spring.
