Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - wheel hopping 69 camaro
Old 07-27-2009, 09:57 PM
prostreet6t9's Avatar
prostreet6t9 prostreet6t9 is offline
Differential/Driveline
Before my car was tubbed I had a slide a link and it worked great. You can loosen the preload when your not at the track and mine was quite.When your at the track you can preload it pretty good for good traction and to correct any launch problems. In the slide a link you will also have to replace the front spring bushing with the solid aluminum bushing supplied in the kit.
