Wheel lug and washer question - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-05-2005, 02:17 PM
raidmagic's Avatar
Last journal entry: Engine going back in the Hudson.
I didn't know where else to put this. I just bought some slotted mags from a local swap meet my probem is the local parts store doesn't have lug nuts or washers that will fit my wheels. I have a pic of the lug area anyone have ideas?
Old 06-05-2005, 05:45 PM
AngliaBob's Avatar
It just takes time and money
Last journal entry: Specifications
raidmagic,
Looking at the pix, it appears you will need mag type lugs(not acorn). Measure your wheel studs and go to the attached site and find the best match.
http://www.gorilla-auto.com/products...=249&sfID2=249
You will need something like the CRAGAR MAG W/WASHERS
Good luck,
Bob
Old 06-10-2005, 02:45 PM
Tazz
Those are called .....
Una-lug wheels...take the wheel to a tire and wheel store and tell them the application...GM or Ford or Mopar and they will sell you the right lug nuts and washers. You will need to torque and re-torque and torque those wheels again...the lug nuts will fall off and so will the wheels....did I say to recheck the torque?? The lug nuts need to be long enough to go almost all the way through the wheel to the other side but stop short of going all the way through the wheel or they will not be able to be tightened...the wheel will be loose and the nuts will be tight...Get the right length lug nuts and you will be OK!!!
Tazz
Rat Rods Rule!
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 10:36 AM
What lug nuts for Torque Thrust 11 western star General Rodding Tech 3 10-16-2004 11:57 AM
Loose Wheel NAIRB Hotrodders' Lounge 9 02-10-2003 10:00 AM
