wheel offset question - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-24-2005, 05:06 PM
53LEDSLED's Avatar
here to learn
Last journal entry: finishing up the skirts
my front wheels have on offset of 120.6, if i get 127, will that make them 7mm closer to the middle or farther apart?. i dont know if this is positive or negative offset, but since they seem to stick out quite a bit, i think its positive so 127 would make them stick out even more? help
Old 09-24-2005, 06:26 PM
willys36@aol.com's Avatar
Wiki Edits: 21
In English units offset refers to the back spacing of a wheel. Thus a 3 1/2" offset will put the tire 1/2" closer to the frame than a 3" offset. SI units are all screwy so I couldn't guess what they mean in metric terms.
Old 09-24-2005, 11:10 PM
1969NovaSS's Avatar
turbo lag......yeeeeehaaaaaaw
wheel offset
Im pretty sure the offset refers to how far the hub is from the center of the rim. I'v never heard of that much offset are you sure thats not your backspacing in mm? Most of the cars you see nowadays have a +40mm ofset. say you have an 8'' rim 0 offset is 4'' of backspacing and then moves from there. I hope this helps you understand it a little better.
Old 09-25-2005, 02:03 AM
chevyhotrod's Avatar
Take a look at this site, this explains a lot.
http://www.yokohamatire.com/utcustom.asp
wheel question need to know fast. iroclife Suspension - Brakes - Steering 2 06-05-2005 12:39 AM
Dumb wheel question. Rubberman2003 Hotrodders' Lounge 5 02-23-2004 03:47 PM
Ignotion Set-ups Native Gearhead Engine 8 11-29-2003 02:20 PM
Hi All I just Joined, Questions Re:454 rebuild Gay-Shark Engine 8 11-29-2003 11:25 AM
Bleeding Wheel cylinder on a 91 corolla ramvrao Suspension - Brakes - Steering 1 03-20-2003 04:38 PM
