Wheel options for 1937 Buick - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-04-2013, 12:55 PM
Mutt's37Buick's Avatar
I would like to use traditional style wheels, hubcaps, and trim rings on my 1937 Buick Roadmaster. (See example picture).
I want to run radial tires that are either 205/70R16 or 205/75R15 because they will be compatible with my drive train.
I've found numerous Buick dog dish hubcaps that vary by year in size with inner diameters of 7.75, 7.875, 9.75, and 9.875.
1) Can anyone recommend a modern 15" or 16" wheel with a 5 x 5 bolt pattern that one of these hubcaps will fit?
Thanks
Name:	37 Buick RestoRod218.jpg
Old 12-04-2013, 02:02 PM
Wiki Edits: 27
caddy
our 37 came with 57 caddy KH aluminum wheels , but hub caps are toast.
Old 12-05-2013, 08:14 AM
Call Stockton Wheel and see what they can find?
Old 12-05-2013, 11:47 AM
Thanks for the info.
I'm hoping to find OEM wheels that will work.
Does anyone know what model year GM began using tubeless tires?
Thanks
Old 12-05-2013, 01:27 PM
Let me revise my previous statement.
Stockton Wheel Company makes a lot of wheels to fit OEM applications; perhaps providing them with your requirements, they could give you a list of suitable OEM rims to fulfill your needs
The Following User Says Thank You to AutoGear For This Useful Post:
Mutt's37Buick (12-05-2013)
Using 1937 Buick instruments in restomod Mutt's37Buick Electrical 3 06-18-2012 05:03 PM
Adaptor '37 Buick Steer wheel - '95 Buick Column? Mutt's37Buick Suspension - Brakes - Steering 1 05-05-2012 01:58 PM
Is welding frame of 1937 Buick OK? Mutt's37Buick Suspension - Brakes - Steering 3 04-26-2012 01:22 PM
455 in 1937 Buick Mutt's37Buick Engine 3 05-13-2011 03:35 PM
1937 Buick lowered Obmlr Suspension - Brakes - Steering 6 11-26-2009 10:14 AM
