Wheel painting - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-21-2012, 03:26 PM
Wheel painting
My wheel have been primed and painted with Duplicolor silver. My question is can i now shoot Nason 496-00 clear coat over them after the seven-day drying period is over. In other words are the two products compatible. I believe the Nason is polyurethane and the Duplicolor is acrylic lacquer. Thanks.
Old 09-21-2012, 08:06 PM
RWENUTS's Avatar
Easy to find out. Test on a spare rim. Spray the primer, dry time then try the clear.
Old 09-23-2012, 10:46 AM
swvalcon's Avatar
Last journal entry: rust on lt body shell
You should be able to clear coat but you will need to scuff sand frist. Use a gray scuff pad and scuff good. Be sure gloss is scuffed off. If you want some added insurance hit it with a clear addhesion promotor like Bull Dog frist then clear.
Old 09-23-2012, 11:30 AM
And by the way, mount the tire first if you haven't. That is the trick to doing wheels, mount the tire but don't bead it. Then you can stuff paper between the tire and the rim paint the rim remove the paper and fill the tire up beading it.
clear coat, duplicolor, painting wheels
Aluminum Wheel Painting / Aluma Prep Application Help Needed jmacs53Willys Body - Exterior 6 04-07-2009 03:58 AM
hubless wheel: Swiss company re-invents the wheel Jon Hotrodders' Lounge 28 03-13-2007 01:36 PM
recovering a grant challenger wheel and painting the wheel itself gothrod87 Interior 0 09-14-2006 07:02 PM
wheel painting F37Oldsmobile Body - Exterior 2 05-17-2006 03:49 PM
Are chrome wheel plugs supposed to be loose in Weld wheel? shockers69 Hotrodding Basics 4 03-01-2006 10:05 AM
