Wheel problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-04-2008, 12:56 PM
Wheel problem
Well, I found the wheels I've been looking for at the last swap meet and they were the right price (cheap). Took them home, cleaned them up and put a new coat of paint on them. Well, I went to try one on the car and low and behold the bolt pattern isn't the same. Measured the wheel bolt pattern and its 5x 4 3/8, the car is 5x 4.5, if this was your car and there was enough material would you or could you enlarge the holes and run a different lug nut???
Old 03-04-2008, 02:51 PM
RE:wheel problem
Hi l don't know tomany people that would do it that way but it has been done, my advise go buy the adapter plates if you really want to use them rims. TROY
Old 03-05-2008, 08:58 AM
Not if I wanted to live to tell about it.
Old 03-05-2008, 09:35 AM
powerrodsmike's Avatar
Wiki Edits: 161
We don't even know what type of wheels these are. You said you painted them, so I'll assume they are steel. You also said the pattern is 4 3/8" ...does that correlate to a metric size?
As was already stated, yo you should not enlarge the holes...... do not do it..
You might get away with it on an aluminum wheel, for a while, but never even try it on a steel wheel.
Even in their best day the wheels with slotted lug nut holes were bad news. I had several sets, one set I even bought new...they all shook like crazy and loosened up the nuts on a regular basis. The old unilugs were a little better, with the fitted oblong washer, but were still a bad idea.
Most aftermarket wheels are positioned on the hub with the lug nuts,(lugcentric) not the hub center,(hubcentric).
As was already stated, get adapters or have your hubs drilled using the proper equipment for the new wheels bolt pattern.
"Cheap" doesn't always work out that way, does it?
Later, mikey
BE different....ACT normal.
Old 03-05-2008, 09:53 AM
Later, mikey
Dammit, you are right on the cheap part. I found that I measured them wrong. The car is 5x4 3/4 and the wheel is 5x4 1/4 does anyone know where I might find an adapter ???
Old 03-05-2008, 10:49 AM
AntnyL's Avatar
Summit Racing should be able to get adapter plates for you. If the plates result in an unacceptable offset issue, one of the custom wheel manufacturers can re-hoop your rims onto new centers with the proper bolt pattern. I know this will drive the cost up, but......you might be better served selling them and buying the correct wheels.
Old 03-06-2008, 12:17 AM
Well, like mikey says, cheap doesn't always work that way. I'm going to cut my losses and just find the right set of wheels. Thanks for all of ya'lls input.
master cylinder interchange runn141 Suspension - Brakes - Steering 7 05-03-2009 05:15 AM
cant figure it out? wheel bearings? bent A-arm? bent spindle? Deadtemple Suspension - Brakes - Steering 9 06-28-2004 07:53 PM
Steering Wheel Adapters Question horvath Interior 17 06-26-2004 06:50 PM
please help..... annoying warm start problem 67cuda Engine 21 03-28-2003 05:44 AM
Fuel / Carb problem DoubleVision Engine 5 10-28-2002 05:18 PM
