wheel probloms - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-31-2008, 01:58 PM
wheel probloms
hey guys
got a 51 chevy and i put a heidt's mustang II Ifs with 11'' disks and 2 '' droped spindles does any one know what size wheels and what off set to use because the wheels im useing are rubing the caliper so i have a clearince prob.
thenks guys
Old 01-31-2008, 02:25 PM
poncho62's Avatar
Wiki Edits: 5
More like what diameter wheel are you using.....14"..15"...16"???
Ontario Rodders
Old 01-31-2008, 03:46 PM
31 five window
Last journal entry: Moving along with patch panels.
Sometimes you can grind the caliper for clearance if it is not too much.I have done this in the past and sometimes you just have to grind off the casting ridges and this makes the wheel fit and the caliper look better.Will not work with all wheels but check and see.
Old 01-31-2008, 10:42 PM
Caliper grindage is sometimes necessary.
Shane
Old 02-01-2008, 01:34 PM
wheel probloms
well im runing 14's but i tryed 15's to and i have the same problom
Old 02-01-2008, 02:08 PM
powerrodsmike's Avatar
Wiki Edits: 161
Many time steel wheels that are designed for drum brakes won't fit even though they are 15" .
On the same token, a 14" steel wheel that was on a disc brake equipped car such as found on an early mustang will work fine. 14" torque thrust II wheels will clear an 11" rotor with an early GM (non metric) caliper ....barely, and the wheel weights need to be installed in the tire..(yes they do that now..$$$)
Later, mikey
BE different....ACT normal.
Old 02-01-2008, 02:17 PM
poncho62's Avatar
Wiki Edits: 5
Mikeys on the right track.........Older wheels designed for drum brakes won't work with disks a lot of the time. The centre portion of the whiil is too flat and won't clear the caliper. What is the bolt circle size?.....then get a wheel for that size that was on a disk brake car.
Ontario Rodders
'39 ford steering column and wheel jim williams Suspension - Brakes - Steering 5 07-01-2010 09:38 PM
HF English Wheel cboy Garage - Tools 31 03-28-2009 07:15 PM
Ford Steel Wheel Tech wheelkid General Rodding Tech 9 01-07-2007 06:31 PM
Early Ford Wire Wheel Tech wheelkid General Rodding Tech 1 06-02-2006 12:15 AM
Bleeding Wheel cylinder on a 91 corolla ramvrao Suspension - Brakes - Steering 1 03-20-2003 03:38 PM
